Enscape settings saved with model
I love Enscape, it’s so fast and such a joy to use, but, and there is only one but, I hate having to save all models as a preset and hunting for them when I open the model and Enscape again, is there any way to save all my settings with the Sketchup model?
I would really like to see this too.
My process just now is to click ‘render image’ button, then while it’s rendering I click the button to make the current Enscape view a scene and type in the description field (in the native application) any changes from the default Enscape settings that I make (FOV, brightness, etc.) By the time I’ve typed that, the scene has finished rendering.
I can then re-create the exact scene with the same settings used at any time.
… one of the biggest problem for an use of Enscape in a pro environment and the problem grows with each new project.
(I agree: That is why I don’t use the “save settings” from the enscape settings dialogue and take note of the settings manually within the scene.)
Thanks for your feedback guys. Do you think that individual settings in addition to settings for the project would be beneficial as well?
by “individual settings” do you mean per scene/keyframe/panorama? If it did this, then saving per project would not be necessary any more and various settings could be saved globally for use in any project: the saved settings would then be for ‘mood’ and ‘feel’ or internal/external/day/night… etc. as a starting point to be tweaked per saved view point (no matter it’s use).
Although, custom skyboxes, save locations and Customization settings could have an option to be saved per project? (If there are no saved settings detected in the same location as the project’s native file location when the project is loaded in the native application, then it uses the default settings)
No I mean like artistic settings that
  • aren’t about to be shared and
  • that you can save and use without any connection to a specific project/view/scene.
? I’m still confused
  • Saving settings in my opinion should be like externally saving a component for a model: available for use globally in any project.
  • However you may need to create a component within a project that is only relevant for that project: it’s created and loaded multiple times within the project, but not saved externally.
  • And you have Groups of objects (settings in this case) that are individual and do not need to be repeated.
I think you are talking about the middle one and I am talking about the top and bottom ones.
Nevermind, we have a lot of constellations and wishes from clients to that topic.
We will come up with a good solution.
Thanks for your feedback!
I was thinking similar to how Render engine plugins work, they keep all details with the skp files, so when you open a previously saved model you just start the render app and hit render, it remembers your past settings.
Like @solo75287 said, the same for Rhino is very missed - simple saved options at the Rhino file. Additional the possibility to save options to a text file and load them later at a new project.
Thanks for your addition @solo75287 @Micha
Same for revit, with the added challenge that multiple people are working on the same file (at the same time). But being able to reliably “re-render” the same view with the exact same settings is important. Most projects present the same views week after week, so people can easily track design progress.
If the settings would be saved in the view, that would make it a lot easier to re-render them.
Your voice has added a further upvote to the existing feature request. Thank you. :wink:
Settings per view is very important. Right now i need to re-render a view and it’s a hassle to recreate the same environment and camera settings.
Jorgensen
Hi there,
we are bunch of people working on the same project in Rhino on different computers. Sometimes I need to change my work place and continue my work on another computer. Or someone need to continue my work from his computer if I’m not there. If I need to render in Enscape I don’t have my scene settings anymore. The settings of the scene always saved locally in Documents. Sure I can copy them from my computer to another one, but unfortunatelly this won’t optimize our fast workflow.
Therefore we have a very big and kind wish for future to make possible saving settings inside Enscape, to be able to open them on other computer.
Thank you!
@Maksym Thanks for your feedback. Topic got your upvote.
@Jonathan_Knoefel Thanks a lot!!!
Suggestion,
It would be great if Enscape could publish a exemplar set of Render settings or maybe you could incorporate these Render settings into a Enscape Interface drop down.
Rob
Perhaps a short term solution could be that if you do the Render in Document option, the information is collected and displayed in Revit with to show “settings used” and you can quickly alter your settings to match.
I’m thinking similar to how photographers often display camera and settings used alongside digital photos.
