I’m working on a project at home and here at work.
Last evening I was working on the project, and now, when i open the project and export the view port into photoshop and place it on top of the image created at home, it does not fit.
Are settings not saved in the file? shouldn’t they match?
Basic thing to check: is the Settings | Capture | Resolution set to a specific size?
And all the settings of DOF, exposure, FOV, atmosphere … etc are saved per machine rather than with the model. (although you can export and import them): It’s one of the big wishlist items that they are saved with the model.
Hey @Jorgensen_dk and @Gadget_1 , the ability to save your settings in the project file itself, is a topic on our agenda which just received a further 2 upvotes.
These settings presets can be freely moved/copied onto a different system, to the same directory, to be selected via our Enscape settings window afterward. You don’t have to think about where to save them, as they’ll always be saved in the mentioned directory automatically.
You can also find a short how-to on the bottom of our dedicated settings presets knowledgebase article here.
Custom Settings dropdown menu:
If you require any further help regarding this procedure, please let me know!
This feature request is on already our agenda and received a further upvote!
If the Windows Documents folder is set be on a server, instead of being set to your “normal” local directory, then Enscape will save the Settings Presets there accordingly instead.
The file is probably so huge because you’ve added some images to be used as “Loading Screen”, “User Interface Overlay”, etc. via the “Customization” tab? Keep in mind, that the corresponding image files will be saved into the Settings Presets accordingly.
Please let me know in case you have any further questions regarding this subject!
The feature request is filed as “Settings connected to Camera Views / Scenes / Project Files”, so we’re aware that (if this gets implemented) settings should not solely be saved in the project itself.
