Enscape Window not opening
Hello
My laptop is an Asus Intel Core i7, GTX 960M, 8GB, DDR4, 512 GB SSD
I just purchased Enscape to use with Sketchup, and the enscape window is not opening.
I have installed the enscape in sketchup and it shows it, but when I press “start enscape” the window opens, it loads “export geometry” and then the window closes and disappears.
Can you please help? I need to present some renderings today and I am stuck.
Thank you!
Hi @marta_alv , whenever you may experience any issues with Enscape like in this regard, please kindly reach out to the technical support team itself directly as detailed here and you’ll be assisted shortly thereafter. Thank you as well in advance for your cooperation.
