how does one set up a sky or bitmap as background??
Re: enviroment
Check out the Training Manual or look at Micha’s starter kit.
Re: enviroment
i have looked at all the manuals and tutorials … i want to render a basic exterior courtyard, i cant find the right combination for intensities for my sun , GI , enviroment , have been battling with this for 8 hours now!!! , just need a exterior vis opt that works!!
have played with hdi,sky , lights in the scene etc etc
PLEASE HELP
Re: enviroment
* use the sun button of the Vray toolbar and add a sun
* set GI and background at “sky” and choose an other sun than “default” (the sun from step 1 should be at a list)
Now you should get a physical sky with a sun.
If the brightness isn’t right, than use the controls of the physical camera or if you use the standard cam, than use the color mapping (“Reinhard”) multiplier.
Re: enviroment
For exteriors, going with the standard (default) set up for the sun/sky/physical camera is a good place to start and usually doesn’t need too much tweeking from that. As Micha suggests, adjusting the exposure is the way to get the brightness where you need. The only potential speed bump would be setting an hdr, and all you need to do with that is make sure the intensity of the hdr matches the exposure that your working with.
Re: enviroment
hi Micha yes i figured it out , eventually , im not use to adjusting something (multiplyer)… on the HDRI file from 1 through to 1000 , usually you only tweak these amounts by a few points , thus i was never seeing any changes ,
Question : what is best to multiply ?
Gi multiplyer, multiplying the HDRI file or the Sun?
how do you set a camera for the above settings … if your backround is sky set to the sun
Am am still not happy with the images , i would like to render with a HDRI file and adjust my camera settings ( exposure etc) and adda few more additional lights … any tips would really help , attached see my visopt file
thank you , it took me forever to browse the forum to find similar problems …
Re: enviroment
have emailed small images to Dalomar
could not upload them on the forum
Re: enviroment
OK, first there was only the standard camera and it works fine with standard HDRI intensities like 1..10 and standard light values. Later the very bright sky was implemented. I used the color mapping multiplier (approx. 0.05) to get down the brightness.
Later the phys cam was implemented, adjusted for the bright sky. Now you can choose, how you like to get phys cam and HDRI together. The default phys cam is to dimmed out for HDRI/lights or the standard camera is to bright for the sky. You can choose, what you adjust - phys cam or color mapping multiplier or HDRI intensity - so my experience.
Do you mean the GI multiplier at the Indirect Illumination options? This options are not for brightness control, this options are for control the intensity of indirect reflected light.
Re: enviroment
hi , the GI multiplyer , the little box next to the GI in the enviroment settings , you can put a number in there … what is that for ?
Re: enviroment
how can i upload an image for you to look at as it says the server is full when i try to up load a 60k image
Re: enviroment
Ah, the GI multiplier at the environment options is active, if you use the color option, no map.
For image upload use a free host service like photobucket.com.
Re: enviroment
It says the server is full because we are no longer allowing images to be uploaded directly through the forum. You will need to use a hosting service to host the images and then you can post them here.
I use www.imageshack.us which is free and will generate the appropriate code for posting images as well.
Re: enviroment
so if i set the colour bar in the enviroment setting , it renders with that colour Gi ?
Re: enviroment
Question : how does one match the exposure to the intensity of the hdr … is it simply by looking or is it more scientific?
Re: enviroment
The easiest way is just by looking. Within a few quick tests you can set it pretty close, and if you have Show Calc Phase enable for IR or LC, then you don’t have to really even let it get to a render (at least for getting it in the ballpark).
There is a scientific way, but that requires measuring the base intensity of the hdr, which is best to do in hdrshop, but could also be achieved through a different setup. Basically, its not worth the extra time, so just go with the trial and error method.
All you’ve really got to do is simply decrease the exposure a bit and you should be good.
Re: enviroment
Your problem seems to be the high ratio between shadow and light. You can use the color mapping “reinhard” burn value (0.8 .. 0.4) to catch the contrast or to change the ratio between sun light and sky light. Set sky texture multiplier higher and sun intensity lower.
Re: enviroment
do i set the intensity of the directional light used as a sun to low in the properties toolbar?
and the multiplyer of the sunlight in the enviroment settings in vray options to high ?
