I’m Fans of Corona .. i stay close with this engine development..
But i have problem with this. why like that ?
It is a 3dsmax issue, you have output path for your render or possibly a render element set to nonexisting path
It happens if you’re using REs without having a global output path specified. It works for a while but all of a sudden this error message appears and your output path is set to your user/documents/3dsmax folder (If i remember correctly). I’m not sure when exactly the error pops up, might be after some renderings or autosave or something like that.
