Error during automatic installation
I got some problems during my automatic installation of Enscape 4.0.1.48.
I use PDQ Deploy and i set some parameters with and without xml.
And sometimes it show me that Enscape returned error code -1 and the log show :
Automatic installation was successful!
[Chaos Group Installer Error]
installation UI startup failed
But in some pc there is no problem and the installation was sucessfull.
Here’s the parameters : -gui=0 -acceptEULA -configFile=“config.xml” -quiet=1
I also tried without xml file and same, sometimes it work sometime it doesn’t.
Also there is my xml files :
<?xml version="1.0"?>
fr
C:\Program Files\Enscape
1
1
1
1
1
Hope you can help me
Best Regards,
Baalane
I am getting the same error with the ver. 4.6 installer. Support has not figured out the reason yet. about half of the installs have been falling with this error.
Not sure this is helpful, when using PDQ (post chaos license addition) I had to resort to copying the installer and xml to a local directory on the remote computers as a step 1 and then running the script from that location. I didn’t get any errors after that. Not the cleanest method, I’m sure there’s a better way to do it.
