error line 5479 during live link
Hi, in some scenes i have this error and livelink don’t start.
Can you halp me?
I think you should ask in the 3dsMax forum. This error is not directly related to Vantage.
I think the problem is due to Vantage.
Let me explain:
The render gpu or cpu in 3ds max works perfectly.
he problem occurs if I use the live link and if, instead, I try to directly export to vantage 3ds max crash.
Well, Live Link uses V-Ray’s distributed rendering code. So there is maybe an issue in this part of V-Ray, but it’s not in Vantage code for sure. I assume your other renders that worked are not DR.
Whoever is going to debug this, they will need a way to reproduce the error, so it would be best if you could share a scene. And which exact versions of Vantage and V-Ray you are using. If you’re not using the latest V-Ray (there is a very recent update available), try updating.
TKX,
I used vray 5 update 1.1,
after the last update the problem is over.
Hi poliedrostudiosrl_pol,
Are there by any chance any IES lights in the scene? Because there is an issue with them which we already discussed in this thread: https://forums.chaosgroup.com/forum/…24#post1109724 and here:Live link does not work - Issues - Chaos Forum which should be fixed in V-Ray for 3ds Max, update 1.2
Alexander
Hi Alex,
yes I have IES light in the scene.
After Update 1.2 the problem is over.
TKX,now I understand the problem !!!
