Exclude light from Reflection...
What’s the way to exclude lights from reflection ?
I know it’s possible to exclude or include an object from Illumination or Shadow casting but not in reflection even if you hide the light.
Thank you for your response
fabe.
The french who speak english like a spanish cow.
affet specular in the vray light
:wink:
thank you, but if I remove “Affect Specular” that will remove it from all objects in the scene and not only the One which is exclude from lights.
fabe
u didn t say so… :wink:
hum…then i can t help u really…
sory
8)
http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=16743&highlight=
:cry:
Hi Jonas,
I’m not alone, it’s exactly what I need…
Vlado, Please, Help us…
fabe
I have the same problem too…
Please Help…
:wink: Are you on holiday, Vlado ? :wink:
Or did some max 9 cause you trouble ? :smile:
Have you see my face when I’m in anger !!! :wink:
<shrug>This cannot be done currently in a way other than rendering the object in question separately and then compositing the two images.
Thanks Vlado…
Ok but it became very complicate when you have many animation…
Best regards…
In that case, could you copy the light so you have 1 with specular and 2 without specular. Then set light 1 to exclude your large sphere, and set 2 to include only the sphere. I haven’t tried it, but I would think it would work…
If it was so simple… Try it… Even if an object is exclude from a light, the light remains visible in reflection
Like Stilgarna, I’ve many pictures and animations which need “reflection-exclude” and “castshadow-exclude”
that would be great if we can turn these option, On, Off
Yeeeaaaaa… Fabe is right…
