I’m just doing some testing and I am finding that even if you exclude an object from a vray light, if the object is reflective, the light appears in the reflection.
In addition to that, if you have an object using the vray fastsss shader, the diffuse component of the light (both vray or max) still effects the object even though it is excluded from the light.
It would be great if this could be fixed because its causing trouble in a scene I’m currently doing that requires custom lighting for different characters.
V Miller
