That’s what I’ve done, works great. You just have to make the (plane+vraylightmtl) invisible to the camera but not to reflections/refractions. Also in the Vray properties disable GI and caustics.
There’s an advantage of doing this instead of having the vraylight produce the reflections - you can adjust the multiplier in the VraylightMtl and change the strength of the reflection independent of the amount of light the Vraylight is emitting.
why so complicated?
I’m doing interiors without any vray lights at the windows…!
you have to check override Max’s in reflection/refraction option under GI environment rollout. increase it to something about 3-5… voilà!
I recommend also the gnomon interior rendering for vray dvd.
I did a lot of interiors this way before, but i found the Vraylight more easy to tweak, and maybe faster for a better result and less sttings to adjust… so that’s why i was wondering if the combination sun/vraylight was possible
But, if I have to adjust a Vraymtl on a plane for each window, i’ll maybe retrun to this old techinque
