hello everybody
long time no post…
here is my latest exterior done with SU7 and vray4SU
i was going for a grungy kind of look, hope u like it
comments and critics are always welcomed…i hope to post more in the future…
Re: exterior view
hi taoklai: a simple scene,a little noise, and it seems that trees on the right dont match with the lightning of those on the left, overall nice image,welcome back, btw the match with the grass looks great!!
Re: exterior view
thx for the reply teofas, i see what u mean with the trees…but i guess it’s acceptable
- i got a bunch of new 2d trees and i wanted to test them out…i’ll post some full 3d exteriors with 3d trees…i want to test how much can vray take
…and the noise is added in ps…maybe too much?
Re: exterior view
yep i know what you mean with the trees, and of course its acceptable,i just mention this little details cause i know what you can do with vray and i wanna mention this , because with out them this wold be a perfect render to me…by the way, as i told you before in other posts im a big fan of your work, nice to have you back bro!!
Re: exterior view
Welcome back! Put me on the fan’s list too! I don’t know if it’s perfect, but, no doubt it’s very realistic! Congratulations!
Re: exterior view
Wow! The grass is very realistic. I think the reflection in the windows is a little distracting though… I think it may be a bit too sharp.
Care to share how the grass was made? I’m very impressed with it!
Great stuff!
Re: exterior view
Very realistic looking scene. Great work taoklai!
and welcome back…
Re: exterior view
10q very much for your comments, it’s good to be back ![]()
steve: for the grass, i kinda’ went backwards on this render, i chose the grass from a wallpaper i found on randomwalls.com and i arranged the angle and lighting after that image. I rendered out a RENDER ID channel and i used color select in PS to select the grass area and pasted in the grass wallpaper. Around the house i used different basic brushes in PS to make it look like grass, by deleting or cloning areas from the grass image. hope this helps (it’s not complicated - mostly postproduction) Good luck!
Re: exterior view - updated
Thanks for the help! But what is a Render ID? Still trying to get to grips with the terminology!
The noise works much better in the second image. However, do you think that the black around the image would work better if it were more subtle like a lens vignetting rather than a border?
Steve
steve: Render ID is a render pass like alpha channel, you just have to add it in vfb channels in the settings (it’s very useful in postproduction)
So essentially, the Render ID is used to create the selection for the grass?
Thanks for all the help ![]()
Very nice render indeed. I really like your colorstyle.
My I ask what kind of filters you use to get those nice color / contrast ?
I like it… what render settings do you use
thx for the comments ![]()
jorgensen: i used nik software for the filters - it’s a photoshop plugin - and i also used chromatic abberation and crossprocesing from photoshop
dw: i used irradiance map and light cache with physicsl sky and camera with hsv exponential color mapping 1:1
