Few problem with 5.1
i’m a new user and i start to testing corona.
i’m trying to fix the crash problem with the support already.
meantime i’m finding few issues.
  • even though it’s tickle the render perfect on the sphere this doesn’t work. i hate to deactivate and activate again to use it.
-when a i do the render it doeasn’t appear the corona viewer, and i have to open it manually. it appears the cinema one.
when i open the corona viewer it’n not possible to use the tool exp, highlights etc etc…it seem possible to use it from the cinema one going into the filter section.
-trying to use the the multipass i can’t see the new layers added in the corona viewer, i can see only beauty and alpha, but it work in the cinema viewer.
  • when i stop the render, the images are different between the cinema viewer and the corona one
Other thing i found:
if i try to do a blend material, when i want to put the mask, i choose layer to insert a black and white picture.
as soon as i click on “layer” to go inside and put what i want it crash.
i hope it’s clear…if it is not i’ll try to explain better with some screenshot
Hi, I tried all the things that you reported and none of them seems to be the issue anymore. If you disagree, please open a new bug report.
Thank you for helping!
