I am teaching animation production at an austrian university (FH Hagenberg) using Vray, helping them get their final diploma come to life.
One very nice project of this years class is named “Fish for Life”
I cannot show the animatic yet, but I am very positive it will get a good short.
It is the story of a fisherman and a fish and there will be an big demand for open sea shots.
I am trying to support them with the setup of the simulation and so I ran a first Phoenix test and I was totally amazed how fast and easy I got what I wanted.
This little test one took 30minutes for setup and (dirty) simulation.
Great hurray to the Phoenix presets.
Now I am want to run a test on the more complex scenes.
Here the sea is not flat anymore, but we are in the middle of a thunderstorm.
My preferred setup should be like this:
big waves are as a poly plane with deformers
only the area of the interaction with the boat/character is a simulation container
so it should be the same setup with the flat sea preset, only the surrounding waves are not flat anymore.
I just started to use the ocean setup of Phoenix and I still don’t understand how the ocean preset works,
that means I don’t see how the ocean surrounding is created (no geo). I suppose it is connected to the sim?
But anyhow this setup wouldn’t serve for big waves.
Here the task would be to connect the poly waves (with displacement driven by the ocean shader) to the sim container fluids
for this kind of big waves check the Ocean texture’s Control by wind speed parameter and the Wave height. Quick preview the results using Pure Ocean option in Rendering roll-out menu. For more detailed horizon set Horizon Roughness to 1 and make sure you’re using the latest 3.05 Phoenix version. Another way If you already have animated geometry for waves and want to use it - shell this geometry and add a Phoenix Body Force to it. It will stick the water to the wavy surface.
? body force
this work good for smaller objects like a logo, but for a big shape like a extruded plane (sea) I was not able to get the simulation under control
perhaps my bad
? ocean texture
also here I didn’t get full control yet
ocean texture is great, because it comes with a lot features built in.
but I would have to tweak the OceanTexture until the waves are in the right shape, then place the boat into this setup and then run the simulation again to get the interaction (splash, foam)
I already asked Veselina Zheleva from the Chaos Group Education Team, if we could get direct support with this setup.
It would be really so great and helpful to see how you from ChaosGroup would set up this shot in Phoenix for Maya. https://my.green-cloud.at/index.php/s/l63pAd85QtayRws
(shot 240)
the simulation doesn’t have to be super fine detailed, as the render style will be stylised.
Thank you so much in advance
Martin
“body force
perhaps my bad”
Body Force must work at any king of scales. Maybe there’s something in your setup. Can you screenshot you current settings or attach a scene with latest correction?
