(Fixed) [HOU-1400] add object properties to HDA
Is it possible to be able to add object properties to an HDA/otl?
Regards Alexis
I’ll log it as an improvement - for the time being you can add the properties to a regular node, open the parameter interface, copy the V-Ray folder and paste it under the OTL->Edit Parameter Interface->root.
All the best!
good to know, thanks!
The shelf tool should work on HDAs starting tomorrow.
Cheers!
Hi, im having this problem now. Using Houdini 19.5.368 and i cant add vray object properties to an hda ive made. is there a new trick im missing?
In the latest nightly I’ve removed all the type checks so you should be able to add properties to any object… Could you pls check if this works for you?
thankyou! appreciated
