[Fixed] White line on the bottom of the video... any solution ?
Hello everyone !
I’m actually working on a scene that gives me some troubles, when I get the final video with After Effects, .mov h264 cinemascopic format, I have a thin white line at the bottom of the video that I can’t delete… And that line does not appear in the After Effects viewport. Any idea about how to fix this ?
A little sample so you can see (only 4 min each frame with low rez, sorry about that)
PS: rendered with corona of course :smiley:
Oh well … Problem already solved, I guess it was because the output format was 1000x563, I just scaled it to a 1280x720, then to cinemascopic 1280x546, and it works just fine…
you can leave now :stuck_out_tongue:
so the line was only in video output, not in raw Corona renders, right?
PS: Interesting WIP!
So this white line was just an excuse to show off what you are working on? :wink:
Will be following this.
Yes, this wasn’t Corona related :wink:
@maru : haha, you’ll be surprised by where this little footage will fit !
a worthy 4 seconds… how did you achieve a flicker free animation? did u use the save GI method? i know thats the way to do it but my 3ds max 2014 crashes the moment i try this method. is it a bug or has the option not yet been made available for use with animations by key master?
You shouldn’t get flicker if you don’t use hd cache.
So, for people interested in this project, here is more related stuff below :stuck_out_tongue:
Go there to see final result :smiley:
Hello P26
interessant!
Raf
