Flickering Noise on Vray Renders
Hi guys,
Im loading some of my old scenes in Vray, and im getting some flickering effects on different parts of the scene, not a certain object/material.
Any idea what setting i need to adjust?
Thanks.
Reset the V-Ray settings to their default (switch to, f.e., the scanline engine, and back to V-Ray).
It should fix most of the issues you are seeing.
If not, simply raise max AA samples.
Should it still be problematic, share the scene here, or send it to our support guys for a look.
Perfect that works, thanks a lot!
