force number of digits in filename number?
I have a network render that outputs 12000 files. VRay numbers up to 9999 with four digit filenames, then five digits from 10000. The batch renamer I use (seq911) won’t recognise this sequence so I can’t rename it,
How can I force a five-digit file number? And if it’s impossible, can anybody recommend a batch renamer that will recognise the sequence so I can rename it?
Thanks.
This one seems to work.
Thanks!
In the end I managed it with one called “Advanced Renamer”.
As a reference for later. I use Rename master or Total Commander’s built in rename tool.
Thanks. I’ll give them a try.
I also use lupas renamer
Thanks.
I’ll give it a try too.
