frame buffer scripting support for changing background
This is really minor, but probably easy to implement. Just wondering when we’ll be able to change the background image of a render in the frame buffer via scripting? We used to be able to do that with the old frame buffer
You still can, but it’s a bit different. This is a sample script to create a Background layer:
vray vfbControl -createLayer "chaos.ref.external" 1
An ID number will be returned for that layer. To change the background layer’s image:
vray vfbControl -layer <id> image "path"
If the background layer is already created you would need to get its id first. With this:
vray vfbControl -findLayersByClass "chaos.ref.external"
You can list all available classes like so:
vray vfbControl -listLayerClasses
Read more about controlling the VFB layers programmatically here.
