Would it be possible to add a simple “color fill” option in the layer “Background” in the new VFB.
Actually we can only add an image. I would like to have a other option with a simple color picker because i often need to see my models on a white or colored background.
You can tell me to change the color background in the environment panel but it changed the lighting or we need to re-render if we changed the color.
Thank you.
I know it will be a few additional steps, but what’s wrong with making a solid color image with Paint and use it?
What’s wrong with making a solid color image with Paint and use it?
Time wasting. Every time we just want to make a preview for a different project/client, we have to open Photoshop/Paint, create a fill image of the color, save it in a correct folder, get back to Max, load it throught the specific location…
It is not like it’s always a white image so i could use always the same. Sometine it need to be black, grey, orange, blue,…
Just a simple color picker background would be very usefull. And mainly to save preview direct from the VFB when we are doing MatteShadow integration without the need to open Photoshop to make the quick comp.
@legi008 Made a script, which renders a VRayColor node and creates a Background layer with the rendered image. Should suffice for now.
color to vfb bg.7z (1.02 KB)
Thanks for the temporary fix. It works as expected
