geometry showing in enscape that isn't in sketchup
Hi!
I’ve got some geometry that I haven’t created on purpouse that I’m seeing in Enscape that I cant find in Sketchup with hidden objects and geometry turned on. Does anyone know what this could be?
I’m attaching screen shots from Enscape and Sketchup. I can tell on wich layer that these objects belong by turning it off and having the unknown objects dissapear in enscape, but I’ve got a ton of other things drawn on this layer too, so I can’t easily take all I want from that layer and delete it.
/Edvin
Welcome to our Forum.
How large is the scene in total and does it help if you reduce the size of the scene generally? Importantly as well, is the scene located near the default starting location (the initial location when a new project is created) and if not, does it help if you move it? Does it make a difference (if possible) if you copy the parts of the scene you want into a new project entirely?
And final question: Is this unwanted geometry always looking the same or does it seem to shift around?
Thank you for the advice!
I inherited the model from someone else, so I dont know if it’s close to where the first objects were drawn.
I’ll have to try to copy the objects into another model.
The unwanted geometry stay the same.
You can also gladly share the scene with me if possible for troubleshooting - Wetransfer.com for example can be used for uploading. If it’s not possible, then please let me know.
