Glass layers transparency issues
Hi guys,
I have problems with second glass transparency. As you can see on the picture. If you look through first glass you can see water features, but you cannot see through second glass. What am I doing wrong?
There is a technical limitation that Enscape can only render 4 layers of transparent material. In most cases this is sufficient. But if you have glass with a depth, you get two layers, add a second sheet of glass and you have 4 layers and the water and you end up at layer 5. As a workaround you can make the sheet of glass 0 width, which gives you only one transparent layer. Visually with sheets of glass you will not see the difference.
