GPU Rendering Stops at second frame with 7.10.00 release
Hi Chaos,
When I’m rendering an animation with GPU RTX on Nvidia 4080 GPU the rendering throws an error after the first frame.
[0h 0m 1.5s] C:\CI\cgrepo\vraysdk\samples\vray_plugins\rt_priva te\rt_opencl_(2158 ): CUDA error 700
[0h 0m 1.7s] [MemoryManagerGpu::releaseUnmappedMemoryFromInstanc e] 700: Could not release device buffer
The same scene works without problems with version 7.0.2.
THe folder mentioned in the error message doesn’t exist on my machine. C:\CI\cgrepo\vraysdk
GPU driver version: 572.16
Cinema 2025.2.1
Attached you’ll find the scene including the log file.
thanks for your help.
Sebastian
test vray 7.zip (168 KB)
Hello sebastian_falkner​,
Thank you again for reporting the crash when rendering animations using V-Ray GPU. We’ve completed initial testing on our end, and I wanted to share our findings and suggest some temporary workarounds while we investigate the issue further.
  • The crash occurs only when rendering animations using V-Ray GPU, the issue is not present when rendering with CPU. Having this in mind, you can switch to CPU rendering.
  • The issue does not occur with older V-Ray builds - V-Ray 7.00.02. Alternatively, you can roll back to V-Ray 7.00.02, which is confirmed to render the animation with GPU without issues.
        You can download this build from here: https://my.chaos.com/download/builds…rsion=7&page=1
  • The scene does not crash when using V-Ray Standalone. V-Ray Standalone is a full-featured and programmable command-line renderer that supports V-Ray’s native .vrscene file format. If you need more information on how to use V-Ray Standalone, you can refer to our documentation: V-Ray Standalone
We’ve logged a ticket internally [VC4D-2835] and escalated the issue to our development team for further debugging and resolution. We will notify you as soon as a fix or updated build is available.​
also having the same issue!
2nd frame crashes
[0h 0m 4.5s] C:\CI\cgrepo\vraysdk\samples\vray_plugins\rt_priva te\rt_opencl_(2180) : CUDA error 700
[0h 0m 4.7s] [MemoryManagerGpu::releaseUnmappedMemoryFromInstanc e] 700: Could not release device buffer
Hello sean_bull, we are currently working on resolving this issue. I will update you when there is progress on it. In the meantime, you can try the suggested workarounds.
Hi all,
You can download from here a stable build with the fix for this issue. Please test it, and let us know if everything works properly on your end.
Rendering GPU Animations with the latest Vray works again.
Thanks for the fix!
Sebastian
