So what number should be plugged into the Similarity field to help smooth things out?
The Similarity should affect very small details of the surface, but to see the effect of it you need to switch between the frames - one up one down.. I would suggest to use the Smooth this channel option instead - if its not enabled. However you can experiment and see if the Similarity actually improves the result or not.
Interesting I count find "Smooth this channel" option. Phoenix for maya.
Ah yes I had that checked, sorry I thought there was a button called Smooth this channel.
Thanks. Its all looking good now.
