Hi
I m running into an issue
I have rendered and rerendered so many times to get rid of any noise effects I see
I use for an interior scene IR map ( 1) and Light cache ( .85)
Noise is set at .001
Adaptive amount at .85
but I still get some noise effect on my leather
Is it because of the material ( I don t have any bump map nor grainy effect on the material ) I would expect something clean
here is an example of what I m saying
Shot at 2007-08-19
Re: Help in getting rid of noise
Three suggestions: use Adaptive QMC 1/16 or/and use more material subdivs like 60 or 80 (and noise 0.005 should be good enough) or jump to the universal setup (Ad QMC 1/100), but with adaptive amount 0.95 (it’s the max value for good IM results, 1 cause problems).
Thanks Micha
I think your recommendations work
I will further test my renderings tonight but it seems promosing
Cheers
Alex
I’m going to suggest a little change in workflow that will help the noise and not affect the IR solution. IMHO you don’t need that low of a noise threshold, and this will help get rid of it.
Step 1: render out IR pass
Adaptive Amount: .85 Noise:.01
Regular IR settings, whatever you normally use
Set up auto save or save once its done
Don’t Render Final Image (also if your using LC, disable secondary bouces as this will get done a the slower settings)
Render the IR map, save it, load it up an proceed to step 2
Step 2: The rest of the rendering
Adaptive amount: 1 Noise:.01
Adaptive QMC: 1/100
Load your saved IR map
Enable LC for secondaries, and disable Don’t Render final image
It may be an extra step, but it will get the IR map done more reliably and the rest of everything will be done much quicker. The Adaptive QMC settings are basically going to be what will smooth out your noise. Try .01 on a small test and see if that works for you, and if you feel that you need it smoother then try .005
Thanks a lot guys
I really appreciate your help
Cheers
Alex
