Help! My ship scene spash and foam disappear
Hi
I am a new guy use the phoenix FD. Can anyone please help me to solve this issue. Even I start it from the “ship in the ocean” official example scene, I still can’t figure out how to fix it.
I am in urgent of finish this scene, can anyone please help me to find out how to fix it? The model was count on cm size but I change it back to meter and scale it up to the real ship size.
Please help me Please :frowning:
Here is my scene file
I think I have the similar problem with this guy. Render artifacts in render sequence not found in stills - Public - Chaos Forum
But how to solve it?
Hey,
Just make your simulator a bit higher and move it a bit down so it can pick the movement from the sides.
So you mean I should make the simulator box more thicker?
More tall so it can use the lower part of the ship better.
Who know how to fix it :frowning: To be honest I don’t want to stuck at this step, I still have a lot of work to do.
Here is the scene - what I have changed is the size of the grid - I have made it taller (and a bit smaller so the simulation runs faster). I have reduced the grid resolution and the Splash birth threshold. I also changed the render settings to it renders faster.
That’s pretty much it. The result is obviously low res, but if you increase your grid resolution and increase a bit the Splash threshold you will be fine.
Ship ddg1000_chaos.zip (4.04 MB)
Wow, you are using a very old Phoenix version and this is why you get the errors. Please update to 3.11.
Cheers!
Can you try and download a newer build? The one you’re using is quite old and I have made it with the latest one that’s why there are so many errors.
Thank you for your reply I will try to update to 3.11, but are you sure when you open the .ma file in maya, maya don’t have any error message pop out once the scene have been loaded.
One more thing is I want to ask, 3.11 support which versions of Maya? 2016,2017,2018?
Yup, all the errors are because of new parameters that we added since 3.04, so the older version does not know what to do with them.
3.11 supports Maya 2015 through 2018 :slight_smile: You can check these here: Download | My Chaos
Cheers!
I update to phoenix FD 3.11, I tried again, but it still not work, what maya version are you using?
The scene I have saved is from Maya 2018 but it should work on Maya 2015 as well. What is the result you are getting with the latest build?
The result is the same, no splash and foam, but when I open
the “ship in the ocean” official example scene, it don’t have any issue, so it is really weird.
Are you using the scene I have sent you, there is a zip file in my previous posts?
