Hi, pls leave ur comment here...just wish to improve some more~~thanks you.
!(Uploaded with ImageShack.com)
Don’t know the result that you are trying to achieve, but to add more realistic feeling to this render, some objects require textures (diffuse; bump; glossy; e.t.c.) to be applied.
Also you can give some noise to the long edges on the floor, in order to avoid those straight lines.
By the way, your houses look nice and the background as well, so if you improve the near environment the result will be even better.
Thanks for your advice Tashko Zashev.
I wish can render a more realistic image. I have add in the texture with bump but the outcome not so satisfaction. Can i have some advice for the texture setting?
And the noise too.
Thanks so much and appreciate for your kindly help.
As far as i know there is a Sandbox tool for Sketchup, which could be used to add more detail to the geometry.
Another way to get roughness surfaces is to use displacement.
Here is a an example with diffuse, bump, displacement and all together :
can’t open the “Capture.jpg” File . . . . . .
Find a photograph of a house and look at it. Look at the differences in the grass (too saturated), the paving (too saturated and too dark), the white materials (far too light), the wood (too saturated and contrasted)
Change your materials to match a photograph.
Could you try again, now you should be able to see the attachment?
tashko.zashev sir,
NO . . . . .
get the MSG . . .
" sketchupmaster, you do not have permission to access this page. This could be due to one of several reasons:
Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else’s post, access administrative features or some other privileged system?
If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation. "
THANKS.
According to our records you have only V-Ray for ScetchUp beta, therefore per our policy you will have full permissions to the “Sketchup -beta testing” section of our forums.
If you have any additional licenses please contact us at : support@chaosgroup.com and we will help you further.
I’m sorry for any inconvenience.
!( Uploaded with ImageShack.us)
That’s looking much better :slight_smile:
Elo,
Maybe I’m wrong but I think the refraction of your railing glass are incorrect. Windows frames are shifted behind it.
And plants at right look blurry.
Maybe the texture of the road should to be retouched because repetitive lines seems visible.
Otherwise, good job compared to your first post.
PS: sorry for my critics. :wink:
welcome for all of your guys comments:smile: either good or bad all are very appreciated! Just let me know any improvement for it. :)Thanks for every one.
Hi LeMisanthrope,
You are always welcome, is ok for your critics~~:wink:
May i know how is the setting for refraction of railing glass? Any suggestion?
Thanks much!
I think there is a difference between windows glass and glasses lens ;), so personally on my windows glass texture, i use 2 possibility. Because windows glass must be “pure” on its faces… The refraction is making only on its edges. (it’s my opinion)
1- I don’t create a refraction layer… I only change the IOR on reflection layer if necessary.
2- I create a refraction layer but I change its reflective black color to white color.
