ok. new project im working on. just started and got a long way to go
a bunch of other things there too
http://www.elfpro3d.com/Ocean1/
Nice render.
heheh along way to go but you still remember the most important part of a pool side render ![]()
Whats your ETA for completion?
nice water Da_elf.
I am also working on a project, much smaller than your’s, and the project has a swimming poll. The problem is that my water always looks bad. Can you give me a little advice on how to achieve the water on your scene?
yeah, very nice water! go ahead on it
Very nice Da_elf, can you show us your color map settings and key light ?, i believe you got a nice balance between bright and dark areas.
Congrats and keep us updated.
Regards
Mark
that was about 2 days of work. im looking to have it finished is about a week i guess. it all depends on if the client asks for changes which they like to do.
as for settings.
water: start with egz glass, convert to vray material then alter ior to that of water. and add in the bump map a mix map with noise in various sizes and phases. maybe even some swirl or wave or anything fun just to give it a nice bump. i suggest you have a default material not see-through and play with your bump map in the diffuse slot just to see how it looks. do quick non-GI renders of it to find a nice looking wave patern.
Lighting: I didnt do much on the lighting. just simply multiplyer of 1 for both direct light and for skylight. warm color on direct light and cool blue for environment. then used something like 0.55 for brightness multiplyer of color mapping with hsv exponential.
looking great so far.
how does it go with linear for color mapping? Just curious as I’m starting to use this more as clients keep commenting that my images look washed out when I use HSV exponential (eg backgrounds)
Are you modelling off of cad plans? The stairs look a little tiny to me.
linear made the colors look washed out actually. but i have “dont affect background” on mine. i never used to use color mapping before i used to use .6 for sun and .6 for skylight as for the stairs i used the drawings povided for the number of steps and used 7 inches for the height of each
Well in that case it may be the chick that is a bit too big… “that’s a huge b*tch”
Other than that nice work mate!
Focusing. there is a tutorial i just wrote on creating swiming pools in the tutorial section now.
Thank you very much Da_elf! I Have manage to produce a rader nice water.
My server is down so I ‘emailed’ you an image.
im always getting pulled between different projects i hate the fact that it takes forever to get one done. here is an update.
and here is another one
looks good so far, do you think the direct light should be a bit brighter?
need help with the sand. dont know what kinda bump map to use
your bushes are starting to look like camoflauge netting. Not sure what to do about it though…
Check your email man.
Hope it fits.
regards
Mark
Personally, I like the bushes… what are you using, displacment? or are they some kind of lowpoly things?
The image is coming along nicely. I wish I could help you with the sand, but I’m in same boat and I haven’t worked out a good sand material yet ![]()
it might just be that the scale is too large for their size. lower scale of diffuse and displacement texture maybe?
Hey man, the files i sent you were so bad that you even say thanks?
or maybe you didn´t receive them at all, at least say something.
I found it very strange dude, no offenses here but when i receive help, even if i don´t like it i say thanks…thats what i have learned in life.
Best regards
Mark
