How can I make stainless steel with vray material
How can I make the material like this?I use vray.Thanks in advanced.
check this library :slight_smile: It has some 140 materials for VRay and has brushed stainless steel.
If you whant to make it by hands, try to put noise map in the bump slot and play with UV settings to get the lines. Also you will have to make glossy reflections, arround 0.5 or maybe litte more.
Hope it helps. :slight_smile:
P.S. need to change extension to .zip :wink:
The file: exs.cx
thank you very much!!! :wink:
I will try it!
You’re wellcome 8)
:: link not working, can anyone please upload!
Many thanks! ::
Try this :slight_smile:
