How to adjust the size of the HDRI background ? ..... I need help please.
hi everybody … every time i use the HDRI in the background it’s so big than my model which can’t give the realistic look … i don’t know how to adjust it to be matching with the scale of my model
any body know how to adjust it
Hi
There no way to control the scale of the HDRI. You can use the repeat option, but you may see a repeated HDRI on the reflection. I use to use and HDRI for the reflection and the place a background image in post process using photoshop or any other post processing software. Also if you want to see the background on the viewport, you could make a plane or a uncap cylinder around the whole scene and apply a material with the background image to it.
Best
thank you so much for your reply …
It is my pleasure.
Best
