how to make soft shadow with default light
since vray sky always make my picture blue, I prefer use default light, u can control where the shadow falls more easily, but u cannot set up area shadow for default light, that’s anoying. any trick?
Re: how to make soft shadow with default light
the default light is actually the sun, so if you set a texSky and choose the sun, you can control the settings. Then when you unset the texSky, I believe the sun will retain the settings, and you should be able to just render with the default light on, with all the settings the sun had.
that’s great trick, thanks
