Ive got a uv set for my colour maps, and a uv set for displacement…but I cant see a way to uv link the displacement to the alternate uv set in the relationship editor. Am I missing something? I have tried to both methods of displacement…vray displacement group / collection, and also putting the displacement texture in the shading group node of the material. Neither seems to show up in the relationship editor to able to connect it to the uv set.
Hi, thanks for posting. You can assign the UV set you want to the texture you want to use for Displacement using 2D Placement Options attribute (added to the place2Dtexture node of the texture using the extra V-Ray Attributes)
Nice! thanks for the reply. Is this in version 5.2?
Hi, this is done with latest nightly version but it is the same with V-Ray 5.2.
Does this work with 2D displacement? I get correct results using “normal displacement”, but errors using 2d
Hi, it does not work with 2d Displacement on my scene as well. Let me check what’s going on and I will get back to you.
The issue is reported under VMAYA-12180 in our bug tracking system.
cool, thankyou!
