Hello I was wondering if anyone has had this issues since I upgraded to 2.4 when I export a standalone file with VR enabled,
the HTC vive does not detect the file and I find myself in the steam waiting room.
I then down graded back to the lasted version of 2.3 and re-export that export works fine and is detect by the VR headset (using enscape 2.4).
If I open and enable the VR headset whilst I’m in Revit (Enscape 2.4) it works fine, its only the standalone file which seems to have an issue.
Hey @GianniBarberi , first off, for your information, you’ll find a little flap to the left after the standalone file has been executed:
This will open the standalone settings. Here, please make sure that you’ve activated “Virtual Reality”.
Although, since you’ve activated the “VR Headset” before exporting though, this setting should already be activated by default, so in that case, would you please be so very kind as to completely re-install Steam and SteamVR? We already received reports stating this behavior before, in all cases this was resolved with a re-install.
