Illuminated Acrylic Effect
Hi everyone!
We are trying to render a woodworking project (a table) that has illuminated acrylic legs.
Attached is a reference image.
However, when trying to create this effect similar to the reference image, the result is not turning out as expected.
We are using the acrylic material from the Chaos Cosmos library, and for the LED effect itself, we are using a rectangular light.
Also attached is the detailed woodworking design to better explain the system we are trying to reproduce in the visualization.
Does anyone have any technical suggestions on how to achieve an effect similar to the reference image?
Hello @silviabitelliarquiteturaeinteriore_silviabitelliar
You can try the following:
  • Set the rectangular light’s directionality to 1 (may need to reduce intensity)
  • Set the Acrylic material’s Refraction > Fog Color to 0.99 white (Hue 0, Saturation 0, Value 0.99), increase the Depth according to the model, and set Translucency to Volumetric. Turn on Reflection > Back Side Reflect.
Here is a hastily done approximation of the reference image. Hope it helps:
Hi Peter!
Thanks for your response and the technical suggestion regarding the material configuration.
Much appreciated :wink:
I had made a similar comment in another post, butif your model just has the table and leg it may not be able to look like your reference photo which is reflecting and refracting other items in the room, but if your room is empty that cannot happen. You could add a dome light HDRI of an interior space and just use its reflection channel to influence you plexi leg and it may give it some more life?
