ilumination objects test
hello
this is ilumination objects test. its calculated with path tracing. in scene is over 100K ilumination polygons. there is corona sun and sky system also outside the room and is visible on left side. ilum objects are in glass objects.
Inspiring :smiley: … Did you try other possibilities(VCM, bi-dir, PPM)?
i tried IR cache + HD cache - it looks useless for ilum glass objects. Path tracing + HD cache looks almost the same as PT+PT, just a little brighter, but 3 times faster - the same quality in 20 minutes not 1 hour (pt+pt).
i got some new tests
Very nice. Any experiences with Photon mapping as a secondary GI? I’m interested in it cause it seems very fast and high quality unless facing reflections(at least from what I seen in my last tests)
so i tried Photon mapping as a secondary GI and balls are black and needs more memory.
this time a checked caustics.
