This attaching simple scene has incorrect Lighting Elements.
What is a problem?
It confirms in Maya 2015/2017 + VRay 3.40.04 +Win7
SceneFile
oak5_lightTest.zip (106 KB)
What is a problem?
SceneFile
There is something wrong related to directional parameter of AAAA light, the strange thing is it even affects the rendering when the light is disabled.
When the lights has been removed everything is back to normal. It’s a bug which we’ll have to investigate and fix.
Seems to be caused by the lights cut-off. By default it is 0.001. Setting it to 0 fixes the problem. You can locate the parameter in the Sampling rollout of the light’s settings in the attribute editor.
Thanx. Svetlozar & Alex
Maybe, it is Bug.
On the following scene, each Light cut-off is 0.0. But Lighting Elements is black.
(Please re-set Reflection Color map path.)
If VRayLightRect37 (Visibility of Maya is turned off) is deleted, Lighting Elements will appear.
check.zip (204 KB)
Thanks for the scene; looking into it. It does look like a bug though - will fix it.
This will be fixed in the next nightly and stable builds tomorrow.
Thank you for fix.
I was about to report this as well.
Thanks for fixing it quickly ![]()
