Installation issue with v-ray 5 and viewport doesn't show simulation
Hi!
When I installing Phoenix FD 4.30 for 3ds Max 2021.3 with v-ray 5 hotfix 2, in the bottom appears a message saying that v-ray 5 instalation was not found. I clicked continue and everything went apparently fine (the exception being that in the V-ray GPU additional files the field being empty).
Opening 3ds Max and trying to simulate fire, nothing shows up in viewport. However, when rendering everything goes fine.
What can I do to solve this?
Hardware: laptop, i7 generation, 32GB RAM, Nvidia GTX 1050
Hey,
Is there any chance you installed V-Ray 5 somewhere other than the default location?
Would it be possible to send the Phoenix log from C:\PhoenixFD after you load 3ds Max, simulate and render?
Cheers!
Thanks for the swift answer!
No, V-Ray 5 was installed in the default location.
I uploaded the log from a simulation made a few minutes ago.
PhoenixFD 3ds Max 2021.zip (189 KB)
Hmm, everything looks fine. I suspect that something might have went wrong with the Windows registry preventing the V-Ray GPU/standalone plugin to be installed. Can you try reinstalling V-Ray 5 and the Phoenix FD again?
I also suspect the viewport issue is unrelated - the same dll that does the simulation also does the viewport preview. Can you show me how the viewport looks and screenshots of all the Simulator’s rollouts?
