Why does the Interactive render window not resize the image to match the resized frame?. It seems to work on 3DS Max. That’s a pain in the neck because if you set your render size bigger than your screen resolution you can’t zoom out the IR window in order to fit your screen.
There is a workaround for now, of setting the max size for the IR, this way if your final render is larger than window resolution, it will still fit. Edit → Preferences → Corona, under Interactive Rendering, set Maximum Resolution to, say, 1200 for it to never be larger than 1200 wide.
(This is not to remove the request for auto rescaling, just to give you some way to work with large final render sizes for now).
