IR rescaling
I don’t know if this is a bug or more like a feature request. I’m not able to smaller rescale the view in the IR. For example, if I set my output dimension to 4000px, I can rescale the view in the final render with the + and i buttons in the toolbar.
In the IR however, this doesn’t work. It will start in full size and I can’t make it smaller. Because of that, I see myself changing the output dimensions to a smaller value, when I want to adjust something in my scene and change it back to my final output afterwards.
Not very convenient.
Is this a known issue or just for me?
Known issue - to resolve for now at least, you can set a max size for IR so that it never is larger than that, and this saves you continually changing your final render resolution. Corona → Preferences → INTERACTIVE RENDERING section, Maximum Resolution (e.g. 1200 for 1200 wide).
Yep it’s a very old issue, maybe as old as Corona for C4D itself. I forgot it since like Tom suggested, I use the Max Resolution setting to ensure that IR is always responsive.
@TomG
It would be nice to see the devs taking advantage of the v9 development to adress all these long standing issues ( nodal editor quirks, instances and motion blur, instances and IR etc. )
I didn’t know about this setting! Thanks alot! This sounds like an easy fix.
Hi there, can you test this with the latest V10 daily build which now has IR scaling?
https://forum.corona-renderer.com/ Chaos Corona 10 for Cinema 4D daily builds - Changelog
