I’m having isses with Max crashing when I’m running the IPR. It seems to be a lot more unstable recently, it’s not a matter of if but when.
For example this morning, in a very basic scene, I launched the IPR and rotated a V-Ray Dome Light, immediate crashed.
It appears to be random, sometimes I can be working for an hour or so without issue before it happens, others only a few minutes.
I’m running the latest releases of Max, V-Ray and I’m using V-Ray CPU.
Do attach the 3dsmax_minidump.dmp file located here (C:\Users\<user>\AppData\Local\Temp) after crashing so we can troubleshoot. Make sure the time stamp matches the time of the crash.
I too have experience IPR | FB crashing but not in max 2024 (not using that), but in every previous version of max.
My take is that it’s not Max and it’s not Vray, it’s the third-party plugins, i.e., forest pack.
The scenes have to be quite heavy for the crash to happen. It doesn’t when you use a very simple scene.
i always proxy vegetation, people, cars,
This may not be in your case reflected on why your scenes crashes.
Vray IPR is unstable, it has been for years, as you guys say editing Forest Packs, editing procedural maps, pretty much anything can cause it to crash. For me it’s improved from a few years back but alas it’s still a little bit buggy.
Send us dump files when that happens, so that we can either fix it on our side, or coordinate a fix with the plugin owner if that is the case.
While we fully appreciate the value of your time, collecting a minidump and firing an email can be done in the time a crashed Max restarts and reloads the scene.
That downtime couldn’t be spent better, so to speak.
