Jérôme does it again
I swap using this
renderers.current=vray()
This code only assign as current renderer engine V-Ray. Simply assign via Render Setup dialog Scanline then back to V-Ray.
P. S. The code drops parameters, but I am not sure that it is enough.
Try the code yourself. It does reset the render settings to default
Yeah that was the first thing that stroke my mind when i tried new 3.3
Must have felt aweful but at least people understood how sampling works :slight_smile:
Can you imagine if you made mastering vray now what woudl be the content? :slight_smile:
Tried the latest Solidrocks and the latest VRay and the render times went down 60%, eg. a 5 hr render went down to 1.5 hours at far higher settings, so not sure if its VRay or Solidrocks or both, tried it on a few more projects and all the same result, a vast reduction in rendertimes.
Mayeb I have been doing it worng for the last 10 years ?
But I like the fact I can just slide to a setting and get the results I want.
VRay it is.
Really, Vray now is SO SIMPLE to optimize, you just have to play around with 2-3 settings at most and you’re done, even for animation. Last time i used solidrocks was 3 years ago, then it was useful, back in IR/LC days, but now?? Can’t get much simpler than it is now.
That’s the beauty of this industry, but fortunately there is still plenty more work to be done and advocate for moving forward in terms of our creative control, material features and effects, the GOOD stuff we should actually be worried about.
Just as a musician doesn’t play better by understanding how the instrument was made, neither do artists do better work by understanding the math.
Interesting… I have an interior that I woke up too only being 1/2 done and 12 hours to go. I raised some settings and lowered the resolution, just to make the proof deadline, and it looked awful. I decided that I would rather be late than show something bad, so I decided to try SolidRocks. With the original full resolution and ‘Very Good’ settings, it looks beautiful and it took about 2 hours.
hmm i might give it a try once again (although i ve done that many times) :slight_smile:
we have a scene that computes quite long so for the comparison purposes out of curiosity if ill be able to download the ugrade for free :slight_smile:
Maybe, I spoke to soon. It’s 13 hours into it, with 4 hours to go, but it is extremely clean. Unless, I cranked it up to ‘production’ because it was going to render over night, anyway; I don’t remember :). I do remember that the jump in render times between ‘really good’ and 'production was huge. I’ll let you know in 4 hours :slight_smile:
Yes, I cranked it up to Production, because I hit render before bed, so the render time didn’t really matter. The ‘Very Good’ settings were pretty good for a fraction of the render time, so I’ll have to do some comparisons.
Here is the 15 hour render. Even with the long render times, I am getting that banding on the ceiling.
I am rendering out a bathroom and I am using SolidRock’s defaults for Interior/IM+LC/Very Good, which is what I used for my first kitchen that rendered really fast and clean. The second kitchen, that took 15 hours, I disabled clamping, subpixel mapping, and Reinhardt. If I leave things at default, with all those things on, it renders 10X faster.
