The new SP3-friendly version of SolidRocks is finally out, and so far my test have been pretty astounding. I have a scene that with the default VRay settings is taking 14 minutes and is very noisy, but with SR on “Very Good” mode, there is hardly any noise at all, and it only takes 6½ minutes! ![]()
I have the beta, but I was finding that I had to set things to there max to get something clean and by that time, the render times were higher that the new V-Ray defaults. Do you remember what SR preset you used?
I just put it on Very Good mode and didn’t touch anything else. That’s it. Though my scene consists of just one complex, but mostly white, medical instrument floating in space (at 4k). I haven’t tested it on an environment yet.
Oh, and on Production mode it took 10½ minutes, and that was only slightly better than Very Good mode.
Downloading now. I launched the beta and it prompted me, which is nice.
Activation didn’t work for me, so I email him. I’m looking forward to trying it.
I have used SolidRocks for, must be 7 years now and it transformed my workflow !
Jérôme ROCKS!!!
Actually, it seems my testing was very flawed. I might not be getting better results after all. I will test some more. My apologies.
I have mine authorized and I’m getting the same speed as V-Ray defaults, but much noisier. If I get same noise level as V-Ray defaults the render times are double.
I haven’t used my copy in ages. I’ll go ahead and re-download. Thanks for reminding me.
The deveolper, Jérôme, is awesome, however, it’s days might be numbered. I haven’t been able to use it in a long while becasue I couldn’t get clean renders at SolidRock’s highest settings. One job a few months ago SR helped out, but most of the times I got a lot of noise or high render times. Let us now how it goes for you.
I have to say i had problems using it all along so its now in my abandonware folder ![]()
Vray 3.3’s variance sampling surely makes any and all tweaking null, all the work I invested into sampling is useless now anyway.
1-50, adjust clr threshold, game over.
hopefully solidrocks has been put to sleep forever now
Actually the majority of my work over the last month or so just does not like the new simplified way. Did one yesterday at about 2K and with threshold of 0.02 I was getting 6 hour render. After doing things manually the “old” way, with 0.01 I was getting a MUCH cleaner image in HALF the time. (0.01 with the new way just sky rockets the render times and it’s still noisy)
It seems very scene specific however since the work I did in the previous month was loving the new simplified way
@Morne
I am pretty sure vlado would be very interested in the scene that works better with the old way.
Personally, if I convert a scene mid-stream, the new render times were horrendous. However, starting a scene fresh rocks with the new normal. I am not sure what would cause this, but I am glad I am working on all new projects.
Yes he has mentioned this to me also and I’m hoping to arrange something afterwards.
Strange that you are finding it like that. There shouldnt be a difference if you start fresh or convert a scene midway or even at the end. Maybe there is something wonky in the code there when “resetting” everything to default
You have to reset completely, (swap to default scanline and back)
