Lampshade Material Question
EZG- I’ve been working on getting the lamp you created to work properly. I created a cone- turned it into an editable mesh. I clicked on VRAY light and positioned it inside the cone. When I render- all I get is black though. I’ve been playing with the settings for over an hour now. When I go up with the multiplier- same thing. Adjusting the materials settings- same too. Is there something I’m doing wrong with the vray light? What were your settings?
Hi Bubujee :wink:
Here’s the scene: http://vray.info/assets/egz/lampbox.zip (max 5 file)
hey egz, thanks for the file.
paul.
Thanks EZG for the file. I didn’t realize one has to raise the multiplier on the vray light (as well as photometrics.) When using max defaults- youre used to values of 1.0 or 2.0 - you’d never imagine 1000- especially when it blows out the viewports!
Well, 1000 is what I have it set for on this particular scene. It involves 2 vray lights with the wax material. I’ve included the material settings here too. GI is turned on. This seems like the magic bullet number/settings as any higher I get white instead of the biege which I am seeking. This isn’t a solid object- it does have some thickness to the shade. I’m still not getting the diffuse light passing through the shade…
-jujubee
looks good juju.
paul.
Try putting the material in a wrapper and increase the GI output.
Thanks cocolas- though it’s still missing something something.
Rerender- your lamp looks the most realistic out of the lot. How the heck did you get that result? I tried following your settings and it renders out black so far. Is it because you have a map in the translucency slot? Can you please post the scene?
Whenever I check the translucence check box, the shade renders out black. What could be causing this?
No maps :slight_smile:
Translucency works best together with glossy reflections and glossy refraction with or without interpolation (Personaly I hate waiting for the pre-passes.)
Here’s the material: http://www.varcht.com/files/LampShade.zip
My scene was in inches and close to scale, light was spherical vraylight about 1 1/2" d and a multiplier of 120.
Ok Rerender. I’m not crazy. Stupid perhaps but not crazy. I used your mat- ditto. Shade is not translucent. Whats the story here?!?!? I realize this image is ugly. The model is ugly. I don’t care anymore about ugly. Just trying to get it to work properly.
Here’s a non-working new image:
and here’s the new max file- had to strip it down due to copy whatnot:
http://home.comcast.net/~charlesleo/basiclamp.max
:x
Bubujee,
When I said solid object, I meant that the walls should have thickness, not that it should be a solid block. Sorry about that confusion. If you look at the file you’ll see what I meant.
hey ezg. I had checked it. I noticed that your file had wall thickness. Guess I could’ve gotten away with using the wax material and wrapping it like rerender had mentioned. Right now im on the warpath to try to figure out how to get translucency to work in my latest render. This is the same mat rerender used- but its not working properly. worse case scenario- ill got with your settings.
-jujubee
bubujee :wink:
a few things were a problem in your file.
1. no GI, you need this to get what you want.
2. the shade wasn’t solid. It had thickness, but had holes in the top and bottom. I replaced it with a tapered tube object.
Here is a quick test:
and the scene:
http://vray.info/assets/egz/basiclamp.zip
thanks ez but I was attempting to use rerenders method this go around as his lamp looked more realistic with the vraymat instead of the beta wax.
bubjee,
the same issues apply to his material as well (it needs the same conditions as the wax to render correctly).
Ok- I think this is the final solution. EZG was kind enough to show me what I had wrong settings-wise. The mat Rerender provided had the translucency fog set to 0. All it needed was one bump up and it was fine. Made me feel real stupid- 6 hours later- doh!!! I’ll hang my head in shame from this forum from now on… :sweat_smile:
p.s. - if you read this far you’ve read too far enough…
juju
I had to try allso;
that’s pretty cool roppin- solid wax?
roppin that looks good could post the scene or some settings,
regards
Hughg
here´s the file :slight_smile:
http://www.roppin.com/images/skarm01.max
cheers
Hughg
