Hi all
Is there way, perhaps maxscript, or another modifier that I can put on top of the stack, that will let me rotate the segments of the Lattice Modifier? (by default it comes in at 45 degrees)
Hi all
I dont believe so. can you not inset the polygons, delete those faces and use shell?
We’re automating the creation of various similar components of different sizes from just using referenced splines. Will have to find another way I geuss
if it’s from a spline why cant you use sweep?
if it’s from an object can you create a macro?
run this, change inset amount to whatever you need. add shell modifier afterwards.
macros.run “Modifier Stack” "Convert_to_Poly"subobjectLevel = 4
actionMan.executeAction 0 “40021”
$.EditablePoly.SetSelection face #{1..999999}
$.insetType = 1
$.insetAmount = 3.19618
$.EditablePoly.buttonOp #Inset
actionMan.executeAction 0 “40020” -- Edit: Delete Objects
$.EditablePoly.delete face
Didn’t think of macro, thanks will give it a shot
