License does not work
Hi team,I did not use Enscape for 3 months due to illness. Today I started it and the message appeared that the license is on another pc, even if it is not. I attach screenshots and his serial. Can you reset the activation, please?
Machine fingerprint: TV8nnyWsEB1xcHsEBUU3F3j9MmOkLwnfw6DUQfEhYHI=
I copy some characters of my serial.
tgEgAe1CnDnVzNgBAEBnkB7s2QEBAFQATGljZW5zZWRUbz1MZXRpemlhIFJpdmV0dGkjRW1haWw9Y…
@Letizia_Rivetti , welcome to our Forum and I’m sorry to hear about this issue.
Could you simply send me your license through a direct message so that I can reset it? In the meantime I’ve also reset your trial time.
In the future you can also always log into your Enscape here and submit a support request to support/licensing via the top right menu, which is usually the quickest way to receive support and/or a license reset if required.
Thank you in advance. :slight_smile:
Thank you!
all solved :slight_smile:
BR
Letizia
Email address: —
Fixed seat license - used seats: 1 of 1(License deactivated)
lisance key;
It’s reset again - I have removed the key/e-mail from your message due to confidentially. :slight_smile:
Thanks :başparmak yukarı::başparmak havaya:
Bonjour, pouvez vous réactiver ma licence s’il vous plait ?
cascarino Alizée
I’m sorry to hear about that - It looks like your license may have been canceled due to non-payment I’m afraid. Please get in touch with licensing by submitting a new request here after logging into your account. Thanks a lot in advance.
Je suis désolé d’entendre parler de cela - Il semble que votre licence ait été annulée en raison d’un non-paiement, j’en ai peur. Veuillez contacter les licences en soumettant une nouvelle demande ici après vous être connecté à votre compte. Merci beaucoup d’avance.
I also can't activate my license. I'm using Mac OSX Ventura 13.1. I can't activate the license. Once you enter the code you get an error message saying no connection. I don't have antivirus and firewall.
Can you help me please?
Thank you
Pardon the delay - Does this issue still persist? If so, make sure to also submit a feedback report with logs in case you’re not using a proxy and have set the firewall exceptions accordingly (we would not reccomend using no firewall at all and yours may still be active, if there is any system administrator you can refer to please make sure to do so too).
Can you also let me know where you are located (which country)?
Hi, good morning
I got a message that my license key has been deactivated because i have reached my fixed seats limit. Im using the same pc as always, Can you help me to reset the license ?
Hi @zhanghua , I have just reset your EDU license accordingly, please try to activate Enscape once more - Whenever you require any further help with activation issues or such in the future please contact . :slight_smile: Thanks a lot and let me know in case anything else comes up.
hi I have downloaded the trial but was only able to use it for one day before it expired, is it possible that I can get a reset please?
Machine fingerprint: opq895L/yHAh5de/z1nXCjh72yKb9K2sXG7ToDfksVc=
Good Afternoon, my customer who uses Sketchup is unaware of any Enscape trial taking place on their PC when they come to install it, or perhaps a long tiem ago did not take advantage of it, has a 00 trial days left on the PC already and wants to trial it out first.
I leave you the fingerprint below, please could you help?
Machine fingerprint: 1f+Fm9/2aPwP+bVP8EBTwjO1l9fkJECnHWjhjJ2QmYA=
No worries - I have granted you each a dedicated trial renewal. Let me know if anything else comes up regarding Enscape please.
Bonjour, apres téléchargement de sketchup 2023 enscape ne fonctionne plus dessus, je souhaite donc utiliser sketchup 2022 (projet urgent) mais la license est désactivée… serait il possible de la
reactiver ?
Can you reset my License too?
I have the same problem of using license on two pcs which I have only one
I have just reset the activation for your existing Enscape license, kindly try activating your key once again now.
Its working again, Thank you very much
Can you reset my license too?
I couldn’t remove it before formatting because my computer crashed
