Light bug
Hi, i’ve found a problem with light in enscape. sometimes light make strange squared shadow on wall.
Hmm, that looks bad. It appears to be light leaking from the sun. Does the pattern change when you change the time of day?
What version are you running?
I just fixed a similar issue, we should have a fix for it in the next preview / version.
it’s not about the sun light, it’s caused by spot and rectangle light.
Don’t know my version becouse if i press About button it give me a error (user webserviceendpoint"
Hey @mammt , in this case it would be great if you could send us the project file for further troubleshooting. Would that be possible? If it’s confidential, you can also kindly send me a corresponding PM instead of posting any download links in this thread. Thanks a lot in advance!
pm’d :slight_smile:
Thanks so much, @mammt , we’ll have a look at it! :slight_smile:
Hello, I have the same problem mentioned above. What was the solution found for him? I have these regimens mainly in IES lights, spheres, and light rectangles. Any light contact on a texture with BUMP generates this bug. This happens in all files. I reinstalled Enscape, changed the version, reinstalled and updated the video card, but none of that solved the problem.
Hi @vzsegala and welcome to our forums!
Thanks for your report. We’ve actually fixed this issue in the meantime and will release it with the upcoming hotfix version 2.6.1. This hotfix should be available within the next couple of weeks, but a Preview version containing the fix should already be available early next week.
Hope that helps!
