Light Select RE supports for VrayLightMesh?
I am wondering if the Light Select render element supports VrayLightMesh?
The Light Select RE works great with regular lights (spot, Rect, etc.). But as I tried to make it work with a VrayLightMesh (converted from a simple plane), no matter if I associate the pPlane1_vrayLightMeshProperties_linghtlink or pPlane1_vrayLightMeshProperties_linghtlink or both to the vrayRE_Light_Select, the corresponding Light Select RE is rendered empty (black).
Thanks,
Jason
Thanks for the pointer; I’ve made a note to fix it.
Thanks Vlado. Good to know it is noted for fixing. I will contact the support periodically to know if it is fixed as this feature is very important to my project.
- Jason
