LightMix and LightLink with vrScene broken!
LightMix pass in scene with vrScene node works property only when vrScene in geometry mode, or LightMix set to Group by LightSelect. If not, when I press “to Scene” button I have this ```
// Error: V-Ray : [VRayMaya::LightMixTransferData::copyTransferSettings] -100: The light setup in the scene mismatches the one in Light Mix //
I can use vrScene with geometry mode in most cases, but not with Yeti.
LightLink with vrScene work only with first item in scene. I load many different vrScene in scene, but I can control with LightLink only first node.
I can’t seem to reproduce your first issue. Could you send the scene and the imported .vrscenes to support@chaosgroup.com so we can take a look? Mention this thread in the e-mail along with your V-Ray and host platform versions.
Thank you for the report in regards to the light linking. I’ve logged the issue (internal bug-tracker id: VMAYA-7412) for developer investigation.
