Good example of Skp to final renderings…
3 work days…
Re: Linear Workflow
Nice work you got there! Two thumbs up!
Re: Linear Workflow
very impressive from su modelling to post processing.
Re: Linear Workflow
Thanks to both of you..
Indeed I always try to minimize the modelling and rendering time to give more to post processing.
I maybe wrong, but I think it is where the creativity is the most usefull and requested ![]()
Or simply where I take most of the pleasure…
Re: Linear Workflow : SU → VRAY - > Final Render
Way to go Tom,
I like the light a lot.
The light cone is volumetric light done in Pshop right?
Keep up that good work.
Thanks Biebel,
yes there are Photoshoped.. I don’t think volumetric lights exist in vray
Actually, I try to use only sunlight and minimise the use of artificial lights.. too long to set up right.. :-[
I don’t like to wait too long to get my render finish .. héhé
Hey Tom,
By far the best Vray exterior I’ve seen to date. Question - where do you get such good trees/sky to add in photoshop?
Hi Tom!
First of all my best compliments for your work: i really think your committer will be so impressed! I would like to ask you just one thing: can you kindly explain how did you get these nice post processed grass?
