Liquid retime
I’m just checking, as I am not getting a good result when retiming liquids.
I am exporting grid velocity and particle velocity/ID. I am then switching my other container to cache index and keyframe from 0 on frame 0 and 200 on frame 120. Set the interpolation to Velocity and it should just work ? :slight_smile:
Anyway, getting flickers of particles all over the place on the interpolated frames.
https://www.dropbox.com/s/5fplhiv5wgpnzvh/PHX_liquid_retime.avi?dl=0
Thanks!
Max 2017/build 1606266837
Edit: Actually hold fire while I preview the mesh! It would appear some rogue particles sitting on the container edge are the issue above. Shall see what happens as deleted that area of the mesh with a slice modifier :slight_smile:
Yep, looks like it is some rogue particles clinging to the container edge, easily fixable… ignore this post! :slight_smile:
Hey,
Interpolation should be just the default, we should hide this control from the user interface - it doesn’t affect the liquids, it’s working only for the fire/smoke solver now.
If there are still issues, please give us a bump. Btw you should expect particles disappearing abruptly when they exit the grid, but the issue in the video does not look like it..
