My colleagues and I have been experiencing a persistent issue with the 3ds Max to Chaos Vantage Live Link over the last month.
The Issue: The resolution set in the 3ds Max Render Setup (F10) is no longer being pushed correctly to Chaos Vantage. Despite having 1920x1080 (HD) set in Max, Vantage often defaults to a much lower resolution (1248x702) when the Live Link is established.
We find ourselves having to manually overwrite the resolution in the Vantage UI every single time we start a session or render. If we forget this manual step, the output is rendered in low-res, which is causing significant workflow delays and accidental “bad” renders.
Any help or a potential hotfix would be greatly appreciated.
